All this eulogizing over the E90
4 replies · 3,600 views · Started 03 September 2007
I do not understand all this praise being heaped on the E90. Let's be honest, it's simply a Series 60 3rd edition phone with a widescreen option and in no way can it be regarded as a legitimate update to the 9500/9300/9300i line.
Can someone with some influence out there tell Nokia to try again, drop the 'Communicator' tag on the E90 (because that's all it is) and reapply it to a device that is a worthy successor but without losing ANY of the functionality of the original 9500/9300/9300i Communicator range. Enough said.
While I respect your right to express your own opinion on this forum, I have to say that I'm really getting tired of the old communicator owner's complaining. Whaa! The E90 doesn't have a fax. Whaa! The E90 doesn't use all the short cuts that I'm used to. If you don't like it then buy something else or use your old communicator. The E90 is a great devive that does everything that I'd ever want.
Mark
Well put.
Right on.
mjlaris wrote:While I respect your right to express your own opinion on this forum, I have to say that I'm really getting tired of the old communicator owner's complaining. Whaa! The E90 doesn't have a fax. Whaa! The E90 doesn't use all the short cuts that I'm used to. If you don't like it then buy something else or use your old communicator. The E90 is a great devive that does everything that I'd ever want.
Mark
