On mine when it's pressed the menu appears and then disappears and if I hold it down the message reader app kicks in.
How are you suppose to set things up so you can work with the menu of java apps? like Gmail, MGMaps and Mini Opera?
I just did a test to see if it works or not. Well� I put Opera mini on the left softkey and it works, even though it has a longer lag at startup.
