Hi guys..
I just changed the cover on my n70 about an hour ago with help from this forum and when I turned my phone back on I noticed all my data was missing (since I keep most stuff on my memory card) like pictures and apps and themes etc
So I went into Menu>Tools>File Manager and scrolled across to the 'memory card' page and it said (no memory card inserted) which seemed weird because it's been working fine up until then! And so I removed and re-inserted the mini SD in the side-slot and nothing even happened on the screen like it normally does when you remove the card. Then a friend suggested I turn my phone off and then back on and that's made no change either.
I'm starting to freak out now...and i'm hoping it's something I can fix! So if this has happened to anyone before or something i'd love you forever if you knew how to fix it! Or even if you knew if it was a problem with the phone OR the memory card..
Thanks.. :frown:
