Update: SmartAnswer version 1.03!
0 replies · 4,375 views · Started 18 January 2003
Symbianware's Smart Ansewr has been updated to version 1.03. Now available in English or German, tighter interface with contacts and much more.
Added in SmartAnswer for Series 60 1.03:
[list]SmartAnswer is available in English and German now[/list:u]
[list]When SmartAnswer gets a call it shows the menu: * Manual answer - Hang up * [/list:u]
[list]Very tight interaction with Contacts application was added. So, when browsing your messages now you can see callers pictures (if found in contacts), and in one key press you can get all the information about the caller from your contacts by selecting 'View contact' command or pressing * [/list:u]
[list]Always-on-top SmartAnswer's indicator was a little bit decreased and moved [/list:u]
[list]During a call SmartAnswer's indicator becomes invisible [/list:u]
[list]When there was a call but the caller didn't leave you the message you can see the line about it in messages marked with blue colour [/list:u]
[list]More 'human' display of durations 😉 ('4 sec' instead of '0:4'😉 [/list:u]
[list]Built-in file manager is added, so you can browse and listen your sounds, messages, etc in an easy way now [/list:u]
[list]Program's menus were fully reorganized to simplify navigation [/list:u]
[list]Both .wav and .amr files can be selected for greeting message [/list:u]
[list]any many other
get it here
Note: Please exit from SmartAnswer before updating to new version!
