How do I set text messages to give me a delivery report, I cant seem to find that option.
Probably a stupid question but�
AGarland wrote:How do I set text messages to give me a delivery report, I cant seem to find that option.
messaging > settings > txt messages > receive report > yes:icon14:
If you are on O2 you need to put this before the message *0#
LEE69 wrote:If you are on O2 you need to put this before the message *0#
just tested it, no you dont :icon14:
Next stupid question�
When connecting to the web, what�s the difference between connecting by MMS, Mobile Web, and WAP?
lol yes you do with 02 i have just tried it 😉
*0# (space) then text.
LEE69 wrote:lol yes you do with 02 i have just tried it 😉*0# (space) then text.
this way is better LOL
AGarland wrote:this way is better LOLmessaging > settings > txt messages > receive report > yes
Mine wouldn't work that way but does with the code,how strange :con?
very strange, i'm with O2 too :con?
AGarland wrote:Next stupid question�When connecting to the web, what�s the difference between connecting by MMS, Mobile Web, and WAP?
I think the only difference may be the homepage; the Mobile Web one has a homepage for use with an HTML web browser, the WAP one has a homepage in WML, and the MMS one has the MMS gateway as the 'homepage'.
AGarland wrote:Next stupid question…When connecting to the web, what’s the difference between connecting by MMS, Mobile Web, and WAP?
Use "Mobile Web". If you check the settings for each access point (Tools, Settings, Connection, Access Points, Options, Edit), you'll see that they work differently.
MMS is for, well, MMS messages. Mobile Web is for Web and e-mail access (and almost any other Internet-based service). WAP is usually charged by the minute, rather than data size. The only thing I've found it useful for is traffic updates on Navicore. The other access methods don't work for that.
