Does anybody out there know how to transfer Gameboy Roms (public ones by the way!) via bluetooth onto the 7650? I see no way of doing this through the Nokia PC Suite...
If you have widcomm properly installed. You can either do it via my bluetooth places. If there is a map called OBEX File transfer. You can place the roms in that folder and they will be placed in the inbox of your 7650. If the folder is not there, you can create it by clicking "Add bluetooth connection". Another easier way is to just select the files you would like to transfer, right-clik them and select send-to->bluetooth->nokia7650. it's that easy....
I have never used Bluetooth (I'll get mine in thursday 😃 ),but isn't there some kind of Bluetooth software or option in windows that can just send files to a bluetooth paired device like it can with infrared?
I dont think you have to use pcsuite for that.
Yeah.
Mouse right click -> Send To -> Bluetooth
