Hi all. I understand that Nokia 7650 default operator logo can be changed. Is the same for Nokia 3650 as per this reference http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=1273 Can't seemed to work.... any advise will be good. TIA. 😉
Help needed on operator logo...
Hi, i think that you and anyone should use the "System Tools" from PsiLOC+, you can download the trial.
This aplication have an option to put any image in operator logo and it has other tools that may be useful to you.
Here you can see the site:
http://www.psiloc.com/nokia/eng/systemtools7650/index.html
I hope this help, because anyone else has help you in this forum.
bye.
o moderators, where art thou moderators? 😮ops:
edit:
:angel: o moderators, our soul angels :angel:
you can try system tools and seleq, they will do the "trick"... maybe there are other progs that do the same, I don't remember it right now
if the "cheat" does not work in 3650 anymore we will be very :cry: sad
Thanks to all... Yes, it is working now... Using the link that I reference to for 7650 previously.
My friend naming convention was wrong and that's why it wasn't working. 😊
with seleq on 3650 you don't even have to rename your op logo
