http://robin.genx.be/review/
Do you like this?
And Rafe if you like it, tell me what functions you need for the site.
I've got full_review_list(); and get_review($id); so far
Do you like this?
Looks really good and simple. 😊
I like it.
EDIT: Dazler - I think I misunderstood what you meant. The editing / adding system looks brilliant. The only thing left is the user side which I'm happy to do if you want?
Dazler - that looks superb!
In terms of the site it needs a way of listing reviews by device in their categories (i.e. the list for the 7650 Reviews page, P800 Reviews page etc). These I would guess can be combined to get a list of all for the main reviews page. It would also be good to have a list for top scoring review (one over 90%, one over 80%). I guess also one for list showing all reviews by gievn author. Also most recent 5 reviews by device.
I can produce these if necessary (just a question of using the right SQL command) - this is what I'll do for WAO.
Looks brilliant though 😊
Same here it looks great 😊
Yes, but I was thinking to get the category and devices from a table or like I use it now, from a file that is ...
We should make sure that we don't hardcode anything .... I'm sure you know what I mean ...
And I wouldn't connect to sql from anything else then 1 general review include file (if we need to change again) ... I'll try some stuff and send it over.
really good!! easy and simple
Dazler:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=6164
This link contains what I did for the user end of the new reviews system and a brief overview of the fields required for entry in the database. If that gives you any inspiration with the PHPing, my skillz aren't up to scratch in that department.
Yes I saw, added your 'date' field, and implementing all the functions needed to generate those list 😊
I think these functions can generate most things required by Rafe and Switchblade ...
http://robin.genx.be/review/test.php
you'll need to get the last reviews from the full list function and the reviews per user 2, Is that OK Rafe? Or maybe better to get a seperate function call for them?
They look pretty much a neat way to go about it mate, good work that man.
/me hunts around for a medal...
