yha title says it, i can't delete lhet last two themes i've instaled even through apps mgr so what can i do now to get them off my device, they are instaled on the memory card and shown in the log, i had instaled another two themes on the memory card before these and thay are there. anyone got any ideas how to get rid of them?
ta.:con? :con? :con?
can't delete themes (even through apps)
Got exactly the same problem! :con?
Aardvark4Design wrote:Got exactly the same problem! :con?
Really! how long you had your phone for and where did you get the themes from?
been there , done that !! same thing happened to me after a firmware update I couldn't remove some older themes that I had installed earlier....
simply re-install the themes again, they will then show up under App. Manager, scroll to theme, click options -> remove
i got it from my local o2 shop on Monday and the themes from some torrent site(but they r all crap!)
monica _69 wrote:been there , done that !! same thing happened to me after a firmware update I couldn't remove some older themes that I had installed earlier....simply re-install the themes again, they will then show up under App. Manager, scroll to theme, click options -> remove
yha didn't do a software update tryed reinstaling the themes just to see and its still the same.:con?
got a url? are yours also instaled on a mem card?
and try www.onsmartphone.com thay have some really good themes.
yeh on the card, try demoniod.com or torrentbox.com :icon14:
I had this problem. Re-installing fixed a few of the missing themes, but not all. For that you should try setting the theme, then setting a wallpaper and remembering the name of the wallpaper file (image01.jpg, for example). Then open up a usb mass storage connection, go in to the memory card on you pc and look for some folders with randomly numbered names. If 1 of those folders contains the wallpaper file you set you know that's a theme to delete, so just delete the folder off your memory card. I know that's all a bit vague but I can't remember where the folders were or anything. I'm sure I found the instructions on how to do it on these forums somewhere, probably under another phone that had the same problem... Good luck!
Themes
babinokia.com/
ownskin.com/index?
gallery.mobile9.com/c/nokia-n95-themes/1/?fi=4
millski wrote:I had this problem. Re-installing fixed a few of the missing themes, but not all. For that you should try setting the theme, then setting a wallpaper and remembering the name of the wallpaper file (image01.jpg, for example). Then open up a usb mass storage connection, go in to the memory card on you pc and look for some folders with randomly numbered names. If 1 of those folders contains the wallpaper file you set you know that's a theme to delete, so just delete the folder off your memory card. I know that's all a bit vague but I can't remember where the folders were or anything. I'm sure I found the instructions on how to do it on these forums somewhere, probably under another phone that had the same problem... Good luck!
wow. sounds hard, i'll proboly try it though, thanks.
LEE69 wrote:Themesbabinokia.com/
ownskin.com/index?
ahh, haven't tryed one of them themes becus ethey don't have the little icons at the top of the page or the walan or calander entrys. bit worried about putting them on becuse of this happning and i can't get them off. do the icons and the rest come up once the theme is instaled?
