Hi Friends,
Recently got my new n95. When I connect to my home wifi through tools>>WLAN wiz. and select start web browsing i get the following error message which prevents me from connecting to web via wifi.
Error = Web : No gateway reply
Can someone help please.😊
any gentleman on this problem? I have not fouund a specific answer to the problem in old posts so please, help.
By the way I am using orange's N95.
Thanks:icon14:
any suggestions on this one?
First, make sure your Wireless router is able to accept new connections (IE DHCP is able to assign IP addresses to atleast 1 more host).
Ensure DHCP is active on your network or Change your phone's IP to reflect that of your network.
You can designate your own IP after you've defined your access point (turn on WLAN scanning and try to use your access point).
After you have done this, goto 'tools>settings>connection>access points' then highlight your access point and select 'options>edit>options>advanced settings> IPv4 settings' and enter an IP address under the same subnet as your network. IE 192.168.*.* (in most cases) subnet mask of 255.255.255.0 (again, depending on your network) and default gateway being the IP address of your wireless router and keep DNS address as automatic.
I would try putting in a static IP address first just to override DHCP on your network which may be giving the wrong gateway or DNS address resulting in a "no gateway reply" error. If you are still having issues let me know.
waxup thanks...i am going to try this at home tonight
Good luck and let me know how you make out or if you have any issues.
