N95 Music Player Question
2 replies · 1,476 views · Started 10 September 2007
On my iPod, if I leave a track I'm listening to halfway through, it'll remember where I was up to in the track, even if I listen to other tracks or switch the ipod off.
This is a very useful feature and one which as far as I can tell isn't available on the Nokia Music Player.
Unless someone out there knows differently? Or knows of a workaround/other application that will do this?
I use my N95 to listen to music on my walk to/from work everyday.
As far as I am aware, when you properly exit the Music Player application it will remember the last track you were playing but it will NOT remember where you were up to within that track.
So, for example, if I exit the application at the 3 minute mark of a 6 minute track in Track 6 of an album, it will restart at the beginning of Track 6 on that album.
If you want it to remember the precise time you were at you could always pause the Music Player without exiting.
But, as far as I know, if you move around from track to track it won't remember where you were up to when you go back. Certainly mine doesn't.
F
Yes this is precisely the issue I'm referring to.
Have (temporarily) given up my iPod now that I have the N95. This niggly issue is one of the reasons why I may go back to it...
What about other music players that can run on the N95? Can they handle this problem?
