P990i Wi-fi help
8 replies · 11,189 views · Started 10 September 2007
Please can someone give me a step by step guide or talk me through how to connect my P990i to my new Netgear wifi router.
I have tried and tried and I am sick of it now😡
Many thanks!😊
What is the problem? Can you give more info?
Does your phone see the router when you do a search for WiFi connections?
Venom1802 wrote:What is the problem? Can you give more info?
Yeah, my phone sees the router its just the setting up the account and then the group account thing:con?
Control Panel - Connections - Internet Accounts
Internet Accounts dropdown at top of screen, select New Account - WLAN
Click on the magnifying glass to search for Wireless networks in range, it should find your wireless lan.
The Account name can be anything e.g. 'Home' 'Work'
You will need to set all the other settings to match your router, if you don't know try leaving on default settings.
If you have done that goto groups, select Internet and then add new account. Find the account that you just created and add it to the list. You can then click on an account name and change the connection priority (Order of points to try to connect to)
Cheers! Did what you said but when I click on the wlan account to connect it says unable to connect:con?
I have a SSID card and password (network key), at no point have I entered the key, do I need to do this somewhere?:con?
Right, I changed the setting from infrastructure to adhoc which enabled me to input my WEP key that windows gave me and I am now connected!:icon14:
Hmm, when I open the browser it says "could not locate remote server" when ever I try to find something ie ggogle, it can't even find vodafone live!:con?
Check the post "How I got my P1i on the Web" (post no. 8) in the "P1 refuses to connect to wifi" thread.
