Update: Extended Profiles 1.50F
2 replies · 3,586 views · Started 19 January 2003
Extended Profiles from PsiLOC is just updated to include the hidden color schemes. And includes some fixes too.
From PsiLOC:
What's new:
- Extended Profiles now fully support SIX COLOR SCHEMES (not available with all phones, seems that all 4.xx firmware versions support it)
- if phone support additional color schemes, Extended Profiles enables new schemes also in standard phone settings
- personalizing current profile automatically applies changes
- assign sound files for clock and calendar alarms for each profile
- assign animated background (only GIF files are supported) for each profile
- assign keypad autolock for each profile
- assign bluetooth settings for each profile
Buy from Handango
Price: Pro $16.95 Standard $9.95
Size on phone: Pro 57kB Standard 50kB
JyriK
Hi Jyr,
i tried the extended profile 1.50 and it says that my phone wont support it. but my firmware is already 4.39. what could be the problem? i there any way to solve this? or is there any other software i could use so that i can activates the other color scheme in my phone? Thnx a lot. 😊
Then it must be that your phone does not have those palettes.
It depends on the operators version of 4.39. they might have modified it.
For more info look at:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=6667
and
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=6687
