I have a couple of queries about the N95 which I hope some of you can help:
1. When I search and connect to a WIFI access point, it asks for a password but if I accidentally typed it wrongly, I can't seem to get the prompt out again. How do I re-input a wrong password?
2. During or after ending a call, there isn't any timer showing how long has the duration been. How do I enable it?
3. Unlike Sony Ericsson, Nokia will only show "1 message received" instead of details on who is the sender in the preview/main screen. Are there any apps that can do the job?
Thanks folks 😊 Not to mention all the battery problems and wobbly sliders of the N95. I wish Nokia did a better job.
1. Kill the active connection and then try again Conn. mgr. -> Act. data conn. -> highlight your connection and then press 'c' and OK.
2. Settings -> Call -> Summary after call -> On
For call duration go to Log -> Settings -> Call duration -> On
3. Don't know.
Thanks for your help. I tried to do this:
But I can't find "summary after call" option. I only have "number of days for logs" in that menu. My firmware is v12. Any ideas? 😞
aoch88 wrote:Thanks for your help. I tried to do this:
2. Settings -> Call -> Summary after call -> OnBut I can't find "summary after call" option. I only have "number of days for logs" in that menu. My firmware is v12. Any ideas? 😞
Menu > Tools > Settings > Phone > Call > Summary after call
I got it figured out - thanks all.
