I've installed my program correctly ("installation successful" message appeared) But when i go to my menu, programs, it is not there.
I have already tried to reinstall it, but it is always the same problem. It is even not shown in the Program manager. However, when i check the folders, all the files are there...
Is the icon i am looking for only a kind of shortcut to the program ? If yes, in which (hidden) folder can i find the actual program to be executed ?
testNestle wrote:I've installed my program correctly ("installation successful" message appeared) But when i go to my menu, programs, it is not there.I have already tried to reinstall it, but it is always the same problem. It is even not shown in the Program manager. However, when i check the folders, all the files are there...
What program? Where did you install it? What version firmware?
Please note that the sis files can contain anything, not only programs. For example you can have a sis which deploys ten JPEGs in E:\ for example. So you may have installed not a program, but just some files.
Also...if you installed to memory card via USB....the app wont show until you disconnect the USB from the phone.
Thank you for the response.
I installed (not via the PC usb connection, but via the file manager in my Phone) The Journey (S60 3rd Edition) onto my SD Card.
I am using the Firmware 11.0.026
From what i ve read about the 12.0.. firmware, i prefer to skip this one. In addition i dont have the time to backup, restore, (reinstall)... etc. at the moment.
Do you know whether the icons are just a kind of shortcut and i can find the executable file in a hidden folder ?
Some programs will only work if installed to a particular memory type.
If you installed it to MicroSD, try re-installing to internal memory.
or...
If you installed to Internal Memory, try re-installing to Micro-SD next time.
testNestle wrote:Great !!This solved the issue !
Thanks.
Which forum member's advice fixed the issue? 😉
