Larger fonts for E50
6 replies · 3,821 views · Started 13 September 2007
I would like to apologise because i know that there is indeed another topic specifically on fonts. However, from what i understood, the font+remover app works on the older symbian os, as i have not seen any symbian 9 platform mentioned in that thread. Therefore i would like to ask you if that app is a safe way for enlarging fonts, and if not, could someone post an app or a link to one because it is very complicated for me to see the very small fonts the E50 has in the adress book for example.
Thank you! 😊
What happens if, in the tutorial I do not use a memory card for changing fonts? I mean, i came up with and idea to use the internal memory, by copying the font files through file transfer in the Others folder, and the with the t-browser to the C:/resource/Fonts. Can this affect my phone?
freelancer31 wrote:What happens if, in the tutorial I do not use a memory card for changing fonts? I mean, i came up with and idea to use the internal memory, by copying the font files through file transfer in the Others folder, and the with the t-browser to the C:/resource/Fonts. Can this affect my phone?
I don't have a clue. I'm satisfied with the default font.
One thing I found when testing larger fonts on the E50 was that it cut the "low" parts of characters like g, j, q etc. Seems to remember it cut the top on some chars also, but I'm not 100% on that one.
Went back to default font-size myself. Didn't waste time with this as I'm satisfied with the font-size - maybe it was some fault on my part... 😊
