when i plug the provided headset in, sometimes i get 3 options to choose,
other times i don't get nothing but a message saying enhancement not supported.
Anybody else had this probelm??
i sometimes get the sticky photo icons probelm as well. is this just a dodgy n95 i have.
PLZ LMK...
Seems an hardware failure... Check the contact between the miniUSB port and cable. That happens when the connection is with Pop-Port, and it�s not very usual with miniUSB port, but could be that.
on the n95 the headphones plug into thier own jack plug socket??
so must be something in there..
Mine is doing exactly the same thing using the provided av adapter and headset. I am, beginning to think its a dodgy adaptor. Not sure if this is a warranty item or not.
