hello... please help me with this.. i've installed this mig33, a messenger application, before & the icon appeared on the applications folder. i wasnt able to use it though because of connection problem..after sometime i removed it via applc mgr. & it was removed.. i tried installing it again but i got this msg. "mig33 already exist, replace v1.1 w/ 1.2" then i press the yes button, but it didnt install, it says "unable to install" what shall i do to completely remove it? i decided to completely remove it coz i found out it's not compatible w/ my n95... is it still somewhere in the private folder... pls help..it's bothering me.. thank you
unable to install "mig33"
You just can use application manager and try to remove. Other than that, is only with a phone format, but only because that is not needed... Install another free Messenger (and more), like Fring, that works without any problem.
