I just joined this site looking for some help and spotted this thread and thought i'd clear up a few points regarding some of the previous posts - And hopefully Someone will be able to answer my query :con?
If you not interested in hearing about t-mobile, please skip to the end to see my query, I would appreciate any help you can offer.
I work for T-Mobile tech support (and do know something about data speeds 😉 )
T-Mobile can set which speed a line is getting it is either 2G speeds (dial up) or 3G/HSDPA
3G is upto aprox 390kB / HSDPA is upto 1800kB - although they are starting a nationwide network upgrade to 4500kB - Accounts are only provisioned with this speed when signed up to Web 'n' Walk Plus/Max.
Also, the Cells that are not upgraded, only a 1800kB total bandwidth is available for HSDPA, so if more than one person is connected on HSDPA then that is shared. Currently the non-upgraded cells can only hold 16 people at any time on HSDPA the rest wait on 3G.
Also, you should not be able to use handset as a modem if on the std Web 'n' Walk price plan, although that is not always the case, but if the systems do identify this is happening, then it will be stopped (so make the most of it while it lasts)
This is pretty much the same for all network providers, but t-mobile have got an advantage, as part of the upgrade the t-mobile network is being joined with 3's network. This means t-mobile will have the largest coverage for 3G and strongest signal strengths than any other network and will achieve it quicker and cheaper than having to build more cell site like the others.
And for those Greenies who sign petition after petition against new cell sites. due to duplication, this improvement is being done while still taking down over 900 cells
Now for my Query 🙄
I have an N95 but the drivers from the Nokia PC Suite only set the port to connect at 460kB per second, so it doesnt matter whether im on HSDPA or not, I cannot get the full network speeds.
But some of the posts previous state people are getting much higher speeds than this, could someone please explain how?
Im using the drivers from ver 6.86(i think) as i have not been able to connect at all using ver7.0 (as have many other people). But as far as im aware Nokia have no plans to improve the speed of the N95 drivers, which is a pretty cr@p considering the hype this phone has had.
Has anyone else released unofficial drivers perhaps?
