Need advice E90 SOFT
3 replies · 2,908 views · Started 15 September 2007
Need some help :
i cant download maps....the nokia map dowloader dont find the card
i can see the card in the computer
Luis
Hi!
This is real CRAPPY software! It looks for the FIRST device that could contain a flash memory card, and just supposes that this is the device witch you want to place the map-files onto... 😮
So if you have some kind of card-reader on your system, most of us do, you can be dam sure this operation will fail! 😡
So, I had to dig out my old lappy without any kind of memory card reader, and use that one...
There should be an user option to select the correct device...
Regards, Storole
