Alarm clock
8 replies · 3,489 views · Started 16 September 2007
Does anyone know why my phone alarm dont sound when its is off ?? its sounds only its turn on ?? its like i set the alarm at 11am and i turn off ...but by the time the alarm dont sound....and i on the phone at 12pm then the phone sound the alarm showing 11am :con?
My firmware is V 5.0719.0.2
I dont use any app. i use the default one (clocks)
And one more thing ,I dont have any alarm set but there is a alarm sign at the standby screen ...only when i lock mi keypad for some time then it disappear
Hey,
as far as I know the alarm can't work when the phone is off. i mean how should it? there's is no electricity the switch on the alarm😉 With off you mean completely off right? Not only in the offline mode? So if you need to set the alarm, just leave the phone on!😊
byee
No, the alarm will work if the phone is off... It will sound the alarm at the set time, then you need to snooze or stop it and then it asks you if you want to turn the phone on.
kontraband wrote:No, the alarm will work if the phone is off... It will sound the alarm at the set time, then you need to snooze or stop it and then it asks you if you want to turn the phone on.
No ,my alarm dont sound when i off it. ..i have tested it millions of times ...another is when i dont have any alarm set ,my standby screen will still show the alarm sign ....
watch this video
http://youtube.com/watch?v=hsXbZ99rm4Q
woah, well I cant 'quite' make out everything on the vid, but its not right.
Nokias have always turned themselves on to alarm. The fact yours is saying contradicting things isnt good... Im not updated to v5 cause I did and it sucked... so Im only on 4.070707
I wonder if anyone else has a similar prob?
same thing here..
alarm work if the phone is off... and then it asks you if you want to turn the phone on.. 😊
[SIZE="5"]Prob solved ![/SIZE]
because last time i used best alarm app n uninstalled it without delete the time slot...i reinstalled back n delete the time slot n prob solved !
I also found out this freeware alarm....try it out !:burnout:
Attachments: Y_Alarms_050_3rdEd.zip (233 KB)
