Help - Navicore Problem
0 replies · 1,450 views · Started 16 September 2007
I've emailed Navicore Support about this but won't get a reply for up to 48 hours and even then don't hold much hope of an answer.
I purchased Navicore Personal 2007 yesterday and installed it by connecting my N95 in Mass Storage mode and it recognised the phone as a memory card.
Installation seemed to go fine and I can load the program but when the GPS activates and has a lock the program causes the phone to restart itself after a varying amount of time usually not longer than about 10 seconds.
Now this is fine if I'm trying to plan a route to a destination 9 seconds away but useless for anywhere further.
I used to have Route 66 installed but I uninstalled this before installing. I've also tried wiping my memory card with no change and also a factory reset of my phone but the same.
Does anyone have any ideas regarding this. I've tried searching the forum but haven't found anything similar.
