Internet browser on my n95 doesnt work anymore. Anyone got the same problem?
7 replies · 3,393 views · Started 16 September 2007
The internet browser on my phone doesnt work anymore. It was working fine until yesterday, and all of the sudden it stopped working. When i tried to open it, nothing happens. You see the phone tries to open the browser but nothing happens. I tried everything but i cant get it to work.
I looked around on google but i couldnt find anyone else who had the same problem. I guess ill go back to the store tomorrow and hope they can help me. I just had my phone for 6 weeks. lol
mine did this a while back,
i just backed up then reinstalled software via nsu and all was well
hope that helps
wayne
07883006441
happened to me too. same solution as tanov.
btw, i'm now on my fourth N95 in 4 months (all replaced by O2). this phone may be many things, but it aint reliable!
i'd have been lost without the knowledge on these forums though. cheers everyone! 😊
tanov wrote:mine did this a while back,
hope that helps
wayne
07883006441
A soft reset will usually do the trick!
hope that helps
wayne
07883006441
Havent tried that one yet. Thx for the tip
pa49 wrote:A soft reset will usually do the trick!
I already did a soft and full reset, but both didnt work. And i forgot to make a backup now al my contacts and messages are gone.
Do you know any way to get them back? Or are they lost forever...
King_Tech wrote:I already did a soft and full reset, but both didnt work. And i forgot to make a backup now al my contacts and messages are gone.
Surely you did a sync. At least you'd get you cantacts back! (don't bother with backup/restore if you do a debrand/update)
it sounds like a reset will do the trick, *#7370# in the handset, make sure you're all backed up using the PC suite, and you should be back to normal, if not contact your retailer, or alternatively you can try opera mini, it's free and pretty good actually. 😊
