Hi, i just got a Bluetooth GPS reciever that i got off ebay:
Can't post links so if anyone wants to look at it- it's ebay item: 320154816999
And im having abit of trouble setting it up, i emailed the people who sent it and they suggested this:
To save you having to read it if you dont want to, basically i need to know how to check the seriel port settings on the N95, and any toher help is most appreciated, thanks
1) Go to Bluetooth settings in the device
2) Check Serial Port settings.
It should be auto sense but just to be sure set it to:
Enable Service
Enable Authorization request
Enable Autentication (passkey) request
Disable Cryptography (it's very important!!! It won't work if cryptography is active)
Baud Rate 9600,N,8,1
3) Enable the bluetooth on the phone
4) Search the GPS device. It will show as JRTGPS
5) Requeste service and enable peer between Phone and GPS
6) Save it on the phone. When it's request, enter the PIN: 0000
