Hi All,
I'm coming to the end of a 3hour unproductive search on how to debrand my Orange N70. I have followed what I think are all the instructions ie in brief:
Download NSS + install
Download Nokia Soft Updater + install
Run NSS, scan phone and enter new product code - write it to phone
Close NSS, run NSU
Search for updates.....NO NEW UPDATE FOUND!!
I've tried a few different product codes but nothing working. Has anyone else experienced this problem? Any ideas on what I'm doing wrong?
Thanks in advance
Did ya use GSM Magic whilst using NSS?
Cos if u didnt NSS wont write to the phone, and the product code wont change!!
Get it here http://allaboutsymbian.com/forum//forum/thread/68453/
Run it at same time as NSS, click the "Enabled" button on GSM Magic, use NSS to change product code, close NSS, close GSM Magic, run update.............
Good Luck!
Will this work for debranding a Vodafone N70? and if so, could someone please post a guide to the process. I read the other post but dont want to get it wrong and muck the fone up.
ayrscot wrote:Will this work for debranding a Vodafone N70? and if so, could someone please post a guide to the process. I read the other post but dont want to get it wrong and muck the fone up.Thanks
I havent looked directly, but pretty sure that u can find that info already published within this very forum..............
Go search......
Good Luck!
