Hi, i need some advise from people who are actively using The Cloud WiFi network (or any other provider in London) on S60 3rd WiFi phone like N95.
How good is connection quality and overall usage experience?
I'm thinking about signing up..
thanks,
z.
I've used The Cloud but only because of Truphone. Had no problem connecting though and the call was of good quality.
thanks, on truphone site i can see that they can login without entering u/p to any Cloud router? is this true? do i have to enter into the contact with Cloud before i use Truphone?
zoltan82 wrote:thanks, on truphone site i can see that they can login without entering u/p to any Cloud router? is this true? do i have to enter into the contact with Cloud before i use Truphone?
Nope. Just dial your number and Truphone takes care of the rest. It recognises The Cloud and logs in for you. No problems, easy peasy.
