Scratched screen
3 replies · 2,252 views · Started 19 September 2007
I've got a couple of scratches on my screen. I was thinking of buying a screen protector but now the damage is done. Can anyone suggest a suitable scratch removing polish for the N95's screen?
I've used Displex on a previous phone. Not a perfect result but not bad unless you're really looking for the scratch(es).
Thanks I've looked at that one but I wasn't sure if it would've been suitable for the N95. From it's description, it looks like it's more suitable for phones with a thick sheet of clear hard plastic protecting the screen. As we know, the N95 has no such protection 😞
I've looked for the Displex stuff on eBay and it doesn't state that it's suitable for the N95. Can another be recommended?
