PhoneTunes - Remote Control for Apple iTunes
3 replies · 3,531 views · Started 19 September 2007
Anyone downloaded this??
I just get wifi signal too weak, or no BT pc found
update: BT works so long as its the only BT connection... (i.e. shutdown pc sync etc)
update 2: Everything working fine now... tunes streaming in house and can change track from any room. 😊
FYI,
When I first connected via BT I had to shut PCSuite down. Once it was connected, PCSuite could restart.
The Wifi set up was very simple.
The software works by creating a playlist in itunes from the songs you chose with your phone. 😊
