Wondered if someone could help me out i installed sDoubler and when checking it out under the files tab there were a list of groups Java apps., Messages, ?????, MGS, PVVideo. and yes u guessed it i accidently deleted the ????? group and wondered if someone could tell me how to put it back its icon looks like the 2 after it like a jigsaw piece. tried uninstalling and reinstalling but no luck! please help as its driving me mad
TIA
Matt (n00b)
P.S. great forum
Well you can add to that list, by select->Add Group.
But as it was ???? then i have no idea as what that program was.
So it would be really hard to say what to add. 😃
I dont have ???? group in there.
Only java, messages, mgs, coctail, pvvideo
Thanks for your reply 😊
you also reminded me it was cocktail 😃
would u possibly know how to add this group, i tried adding this from groups list but dont know wot group to add 😞
Thanks,
Matt.
You have to have coctail installed for it to work, I guess.
If you dont have it, its useless to have it on the list too.
Best thing for sDoubler is Stacker60 😊 Stacker60 is ace... Not being asked to promotoe this software or anything but it is real good! Have fun!
ok thanks JyriK, guess that clears that one up then 😊
and zipper you conldn't have told me this the day b4 yesterday? 😊 bought sDoubler first and im gonna get my money worth outta it first but no doubt i'll check out stacker and maybe check here b4 i buy anything else 😃
Thanks again
Matt
