how do i know if my n73 is the music edition?
is all black and when i do the *#0000# i get
V 3.07.4.1.0.1
19-01-2007
RM-133
Nokia N73 (30.01)
wouldnt it say something like Nokia N73ME or something like that?
the reasion i ask i that the the sound is very quiet and poor when playing mp3's, i changed from the standard headset to the nokia mutimedia one (HS-20, AD-41 ) and there is no change its still very quiet and poor. is it normaly like this?
thanks
If it's a genuine ME (ie it was factory-born an ME, not upgraded to ME firmware) it will have a dedicated music player key (two musical notes (beamed quavers if you want to be technical!)) instead of the media key (diamond).
http://www.allaboutsymbian.com/reviews/item/Nokia_N73_Music_Edition.php
The music player should have options to alter the sound quality in the Loudness and Stereo widening options plus equalizer options.
and use some task manager to see if music player loads at startup...if it does that means that it is a me...
ah, mine has that "music note" key, but when i press it it doesnt go straght to music player it goes to like a dimond setup where up on the joystick is the radio, left is the web, right is the gallery and center is music player.
my muisc player doesnt have the spectrum, album art, stereo widening and loudness just a equalizer
would it need upodating from the nokia website then?
You need to update the firmware. Go to the following site for instructions. Any problems come back and the guys will sort you out.
http://thenokiablog.com/2006/11/28/how-to-update-original-nokia-n73-firmware-to-music-edition/
i just tryed to update using the nokia software updater and it said that i am running the up to date version -
V 3.07.4.1.0.1
i am going to try the link above
ok i followed the details on that link and everything is now working, the new media player is loads better and the sound is loads better on loud speaker but my headset dont work anymore. every time i plug it in the phone tells me that "the enhancement is not supported" the same goes for when i plug my hands free car kit in and the headset that came with the phone. it was all working fine before the update.
any ideas?
Very strange. I am on the latest FW and my AD-41 works just fine.
thesonofthedevi wrote:anyone got any ideas?
Should all be working. Have you tried checking Settings/Enhancement to make sure everything is set up ok ?
bidboy wrote:Should all be working. Have you tried checking Settings/Enhancement to make sure everything is set up ok ?
yeap, it was all working before the update.
i mite just phone orange and tell them its broken and see if they send me a new one out
