Hi
I don't have my instruction book to hand
Can you guys tell me if i need to switch of my phone to swap my memory cards over
Hi
Nope, go to Menu -> Tools -> Memory then press Options and select Remove Memory Card. The phone will then tell you its ok to take it out.
riverboat wrote:Hi
Can you guys tell me if i need to switch of my phone to swap my memory cards overThanks
No need to power off.
Press the power button briefly then select Remove Memory Card
thanks very much😊
