Problem connectiong to GPRS
5 replies · 1,227 views · Started 19 January 2003
when ever im trying to connect through gprs
with Webviewer,wap and also email I get the message that its connectiong but thats all it shows connecting connecting
nothing else happens and the GPRS sign is blinking
anyone have an idea what might be the problem??
the settings fine and for Webviewer the gate way Ip is 0.0.0.0
you think in got something to do with my service provider??
any advice would be appriciated.
Are you sure you have a GPRS connection from your operator?
It does that if you dont have.
Yes im sure
I dident have it few days ago though but then when i would try it would show the message connecting for 5 sec or so and then it would disconnect
but now it just shows the message connecting
When is the last time when you restarted the phone.
Sometimes the GPRS connection hangs up, and only way to fix it is to reboot.
yes i had noticed that too,the gprs connection hung up
but thats also not the problem,I called the operator he said there's some problem in the GPRS thing their gonna fix that in a day or 2
so then ill wait and see
