N95 not retaining WEP key for wifi
2 replies · 2,841 views · Started 21 September 2007
Hi
I have recently been given an N95 as a birthday present, and I can connect it to my wireless network without any problem if I enter the 26 character hex WEP key.
The trouble is that I have to enter the key every time which is a bit difficult to remember 😊 I have tried using the WLAN setup option and entered the key there, but it still asks for it the next time I connect to the WLAN.
Does the N95 have the ability to retain the WEP key or am I just going to have to key it in each time?
astradyne wrote:Does the N95 have the ability to retain the WEP key or am I just going to have to key it in each time?
Most definitely yes. Otherwise it really would be a pain. 😉 Try defining the access point within Tools>Settings>Connection>Access Points rather than the WLAN wizard. it should store it this way (though I'm not sure why it's not remembering it the other way).
Thank you for that, it worked a treat. Now I just need to order a bluetooth keyboard and I'll be laughing.
Thanks again.
