battry problame
8 replies · 2,508 views · Started 22 September 2007
I brought N 95 10 days back.I had n 75 befour this phone.bettry was working like for 2 days.I am using n 95 with same style but bettry is enough for 6 8 hours.any body else also fasing same problame.I am really dis apoointed.
is there any othe way to increse capasity of battry????
drsanket2000 wrote:I brought N 95 10 days back.I had n 75 befour this phone.bettry was working like for 2 days.I am using n 95 with same style but bettry is enough for 6 8 hours.any body else also fasing same problame.I am really dis apoointed.
It depends on what you do with your N95.
I can get 2 to 3 days standby from the battery if I don't make lots of calls/SMS.
WiFi, USB, GPRS Packet Data='Always On', 3G Mode, and Music Player are all big consumers of power.
* Ensure packet data (in Tools->Settings->Connections->Packet Data) is set to When Needed.
* Disable VOIP and other Wi-Fi connections when not required.
* Set Network Mode to GSM if 3G network functions are not required (or if you are not in a 3G reception area)
* Charge your battery overnight, every night.
Hope this helps.
thanks for reply
but I almost use in the same way how I use t use my N 73 but I really feels difference.Is it possible tht this phone is heaving low battry capesity?
drsanket2000 wrote:thanks for reply
I experienced a 30% improvement in battery life after the V12 Firmware upgrade
What FW are you on? (Type *#0000#)
Also with new phone/battery it improves quite a bit after some 10-15 charges. Also, as mentioned, charge it often (LiOn batterys likes it..) and most importantly DO NOT COMPLETELY DISCHARGE the battery.
why not let battery empty? do u think they will ever bring out a higher capacity battery for classic n95 or just carry on capitalising on thier mistakes by bringing out brand new expensive versions of the same phone.How about a free n95 8 gig exchange option for every classic owner. I think not.
try keepin phone in gsm mode instead of dual my battery life is almost twice as long if you dont use 3g, if u really need it u can swap modes on the go with no need for reboot.
dscobsct wrote: why not let battery empty? .
The combined wisdom of AAS users agrees that you will shorten the life of the battery if you completely discharge it on a regular basis.
dscobsct wrote:
do u think they will ever bring out a higher capacity battery for classic n95 .
No. You can only fit so much capacity into a physical space. That's why the higher capacity N95-8Gb battery is larger and does not fit the classic N95.
