Packet data question
2 replies · 1,630 views · Started 22 September 2007
The amount of packet data according to my phone's log seems to be a lot less than the amount that the Nokia browser says it is downloading. For example the page says that I am downloading in excess of 2mb, but when I check my log in the applications section it is nowhere near this.
Which amount am I likely to be charged for, and what could be the reason for the difference?
The log which displays total sum of all data does not include WLAN activity.
The detailed (each connection) log does display both. Worth mentioning though is that as long that the connection is still active it's not updated. Hence, close all active connections before checking the log.
Thanks for your response, but I am not using WLAN for this. I mean that I mean that in the top right hand corner of the browser the amount of kbs clocks up, but when I check it against the log in the applications the amount is much less.
Does anyone have an explanation for this, and are they experiencing the same thing?
