Is there any way to disable the Welcome application so that it doesn't run every time my N95 starts up? I don't want to remove this application; I just want to keep it from running automatically upon boot-up.
Thanks in advance.
[RIGHT].[/RIGHT]
Thanks in advance.
[RIGHT].[/RIGHT]
HippoMan wrote:Is there any way to disable the Welcome application so that it doesn't run every time my N95 starts up? I don't want to remove this application; I just want to keep it from running automatically upon boot-up.Thanks in advance.
[RIGHT].[/RIGHT]
Why not delete it? If you don't want it why keep it?
Even if you delete the Welcome App, it can be restored by a Formatting the internal memory (*#7370#) or after a Firmware Upgrade.
dez_borders wrote:Why not delete it? If you don't want it why keep it?Well, I do want to keep the Welcome application. I just don't want it to run automatically every time I start up my N95. I still want to be able to manually invoke it when desired or needed.Even if you delete the Welcome App, it can be restored by a Formatting the internal memory (*#7370#) or after a Firmware Upgrade.
I didn't know about *#7370#, so thanks. Maybe I can live with that option. But before I delete Welcome completely and rely on formatting the internal memory if I ever want to restore it, I want to make sure that I understand what will happen to the rest of my N95 configuration if I reformat internal memory. Will my N95 go back to all of the default factory settings, or does this reformatting only affect the Welcome application?
Thanks.
*#7370# will reset your N95 back to factory settings (you'll lose all personal data).
I found that if I said "yes" to the Welcome app, and went through at least one aspect of it (rather than pressing "cancel" or quitting half-way through), it stopped bugging me every time I switched on.
R
robgreb wrote:*#7370# will reset your N95 back to factory settings (you'll lose all personal data).Aha! That worked for me. Thank you very much!I found that if I said "yes" to the Welcome app, and went through at least one aspect of it (rather than pressing "cancel" or quitting half-way through), it stopped bugging me every time I switched on.
R
