Is it possible to use the n95 with a laptop to use internet on the laptop ?
Never been able to work this out.
thanks
thanks
nudda wrote:Is it possible to use the n95 with a laptop to use internet on the laptop ?
Never been able to work this out.thanks
Yes,
Download the modem drivers from nokia support site in case they are not already installed. Connect the phone by the USB cable. Start PC suite and use the connect to internet icon. You can accept auto settings or input them manually.
thanks much.
apparently with pc suite installed, all you need to do is press internet icon and thats it. no need for drivers etc. way cool
And you will have to set the service manually - choose phone, choose ISP ... done.
I'm getting 1.3 Mbps on T-Mo 3G and use it on my lappy all the time.
Well nudda , you easily connect your nokia n95 to laptop for net browsing. I am telling you the consequent steps. Get the Nokia PC Suite from their website & install on your PC, then connect your phone to your PC via USB cable. Open PC Suite and choose 'Connect to the Internet', then you choose which connection you want to use (GPRS / 3G/ HSDPA / EDGE / etc).EDGE will be best option if u need quality speed.
thanks babe
