n70, new 1 gb mmc, cannot transfer quick office from old mmc
4 replies · 2,580 views · Started 23 September 2007
hi,
I have Quickoffice installed on my orijinal mmc that came with my n70 on a 64 mb nokia mmc. I need to transfer Quickoffice to the newly purchased 1 gb sandisk mmc. Tried to copy all files including hidden ones by a cardreader for my pc but the files cannot be copied on winxp. It'd be awkward to change mmcs all the time whenever I need to open a quickoffice file. I need a path to follow. Thanks for your time and kind follow-ups.
It must be possible, since I did it in the same way, using also Win XP. Try on another PC or another card reader.
ratza: card reader when connected to XP can read the 64 nokia mmc but shows the quick office files with wrong names including chracters such like #, $, <, or meaningless numbers. And when you see files like that you cannot copy them as you know. Can you recall what brand your cardreader was and your XP's language settings? I might try to match these if possible. Thanks for your kind reply.
