VOIP - Hide Number
7 replies · 3,343 views · Started 24 September 2007
I want to call abroad but at the same time I dont want them to know what country im calling from. Is there a way of using any VOIP client that will allow me to have any number I desire?
I've tried truphone but its a 0044 number?
I have no clue if this would work, but Settings > Phone > Call > Send my internet call ID might have some impact? Might be worth a try, for SIP services like Truphone.
Ive tried both truephone and gizmo but both of them display a 0044 number. I need to be able to show a number that doesnt relate to A UK dialing code.
try eutelia
italian service gives you numbers from almost everywhere
h__p://www.euteliavoip.com/index.php?lang=en
support is really bad, but if you can make it working you can get a landline number from quite a few european countries
check it out
Cheers for the link m8, been trying to configure it with no luck.
Any ideas how to configure it with the N95?
try www.voipcheap.com
if you use a public sip-code with a number it will show, but if you use a sip-code with a "letter-username" you get no caller-ID..
VoipCheap is cheap and functions perfectly on a N95!
i wrote this in the italian forum, it should be easy to understand
menu > tools > settings > connections > sip settings > new sip profile > use default profile
poi inserite qyanto segue
profile name skypho
service profile IETF
default access point IL NOME DEL VOSTRO ACCESS POINT
public user name sip:[email protected] dove XXXXXXX e' il vostro numero skypho
use compression no
registration when needed (in caso contrario skypho si colleghera appena entrate nel raggio del vostro AP succhiandovi la batteria)
use security no
poi nel tab proxy server e registrar server inserite quanto segue
proxy server address sip:voip.eutelia.it
realm voip.eutelia.it
user name 06XXXXXXXX dove XXXXXXX e' il vostro numero skypho
passwrod LAVOSTRAPASSWORD
allow loose routing yes
transport type UDP
port 5060
copiate gli stessi nel registrar server
uscite e andate in INTERNET TELEPHONE (sempre sotto la connection usata prima, dovrebe essere sotto sip settings)
new profile > select sip url > trovate la connessione appena fatta sopra con il vostro skypho number (se avete solo un numero voip sara facile) > dategli un nome esempio skypho roma
sip
