I was thinking about putting all of my nim converted music and other video clips on the n9210 website. I have 150, yes thats right 150 music and other style clips. Also clips of me thrashing my 355. But I might just design a website of my own!
Anyone got any tips on this and where i could get a free one from, or if there not that expensive tips on buying a web name and site?
Designing and making a website is free, you only need a text editor and an HTML reference. getting webspace for 150 .NIM files will be *VERY* expensive, if you buy from somewhere that will sort out your domain name and give you webspace you may be looking at up to �50 a month renting the space to store the files, more if they are larger than I'm guessing.
You could run your own server but then you'd need a cable/dsl line with a static IP address and a webname redirection service. You'd also need a PC to be setup as a server with Linux & Apache on it. You could run Windoze and IIS but that's expensive and will be hacked to kingdom come. In the long run if you've got over 100-200 MB it'll be cheaper to run your own server in the long run. Remember that all this money is outgoing though, web advertising will make you a pittance back.
Or you could send them to me and I'll put them on my website
www.n9210.co.uk
Thanks for the advice switch blade,
I'II be posting them on the n9210 website this afternoon, I can't really be bothered with all of the designing a website stuff.
See Ya
If anyone wants a copy of the nim video's I've got then just send me the cost of postage & packaging and a recordable CD, email me and I'II send you my details.
Although i will be putting a few on the n9210.co.uk website.
SEE YA.
