Display copied system folder
1 replies · 1,674 views · Started 24 September 2007
Hello,
As newcomber maybe somebody can help me with the following problem. I found similar descriptions but few answers.
When I copy the Folder system/apps/*.* with Nokia PC Suite's File Explorer from my PC to my N70 SD Card the Folder does not display. In the File explorer on my N70 however the Folder is visable.
The problem occurs that if I want to copy new files tot a subfolder in \system I cannot find the folder with the Nokia PC Suite's File Explorer.
Thanx
You should also change the attributes. The folder is hidden so this has to be removed. Anyway, I'm not sure if you'll get it to work and be seen in PC Suite.
