N95's Secondary Camera
4 replies · 1,888 views · Started 27 September 2007
What's the megapixel? I couldnt find any threads about it. The megapixel of the second camera. I guess just like N80.. Like.. A 1.3 or something.
It is 0.3 megapixels, 640*480. It seems really to be meant for video calling more than anything else.
tenlientl wrote:What's the megapixel? I couldnt find any threads about it. The megapixel of the second camera. I guess just like N80.. Like.. A 1.3 or something.
I just took a picture on it and the resulting image is 320x240, more like 0.07 megapixels! I don't think you can choose what resolution to output at, so that seems to be it. It's only really designed for video calls.
How did you take a picture with the secondary camera? Can you actually choose which camera to use?
In the Camera program, the second item on the options menu is 'Use secondary camera'. Alternatively, if you open the Camera program from the menu rather than opening the lens cover, it will use the secondary camera.
