about to order a n95, couple of questions..
2 replies · 2,079 views · Started 27 September 2007
Does it have the lock feature that locks the phone so you have to enter a pin to get menu access like other S60 phones?
will it have a transfer feature so I can transfer all content via bluetooth from ym N73 INCLUDING text/mms messages?
Liam
I answered part of your question in your other post. Re the second part, yes the N95 does have a transfer facility, where content can be transferred but the extent depends on the type of the other phone. Not sure about txts but if you've used Lifeblog in the previous phone, you could always copy those across with that.
Anyway, Tools > Transfer >Transfer data is the way to get contacts, calendar etc across.
my n73 does have lifeblog.
I have never used it though.
Basically I have a folder full of messages that I would wish to transfer to my N95, i thought the transfer option would do it?
If not how do I do it using any other means including the lifeblog route?
thanks
Liam
