Update: Space Doubler v1.30
0 replies · 2,917 views · Started 19 January 2003
PsiLOC has updated again the Space Doubler, this time adding more option to compression and making it faster and smaller. Buy it here
From PsiLOC:
What's new in version 1.30:
- it's MUCH faster (50% faster if optimized for speed)
- four compression levels:
- maximum (up to 10% better compression ratio)
- normal (up to 5% better compresion ratio, the same speed as before)
- fast (up to 20% faster)
- fastest (up to 40% faster, slightly lesser compression ratio)
- all compression levels are still ZIP format (files compressed with Space Doubler can be extracted using e.g. Winzip)
- Space Doubler application size is 15kB SMALLER
- faster and more discrete start of compressed applications
- ability to create shortcuts to compressed applications in standard Favourites application
- application/group settings added (e.g. frequently used applications may be optimized for speed with fastest compression level, others with maximum compression level)
- Space Doubler is now fully automatic, it detects new applications and asks about compress it (no need to run main program after instaling new application)
- ability to "sign" or not application icon
- Repack all applications option added
- smoother progress indicator
- other changes...
- and it is available as FREE upgrade to registered user's
More info:
http://www.psiloc.com/nokia/eng/sdoublerS60/index.html
Buy it from:
handango
Price: $9.95
Size on phone: 56kB
JyriK
