Accessing installed application
1 replies · 1,707 views · Started 27 September 2007
Hi all,
I spent the last 2 weeks writing a benchmark for my nokia N70. I finally made it to work and generated the .sis file. After enabling software installation, I managed to install the application and it shows the application as installed in Application Manager.
The problem is I can't see any way of actually running it. I didn't get a shortcut in "My Own" category and I don't know how to start it. It's really frustrating 😡
Do you know if the shortcut creation is automatic for each software you install, or I should have done it while programming the app.
Is there any oter way to run it?
Thanks in advance!
RH
