Had a problem with route66 for a long time now, and i have just formated my memorycard and reset the phone preferences, but still it starts for a ½ sec and then am back in phone menu again.
What is the damn problem?
When i reinstall route66 it says that it is installed allready: Do you want to overwrite blabla.. so apparently am not able to delete Route66 totaly and start on a new fresh install?
How do i format my internal phone memory, because i guess thats the problem?
That i am unable to start over again with the install.
Or what else could be the problem to this?
again, jumps back to main menu ½ sec after i opened route66...
Really need help with this.
What version of Route 66 are you running? Is it the .486 or the .545 flavour?
Aurial wrote:What version of Route 66 are you running? Is it the .486 or the .545 flavour?
Its .486 and i have a working cert and everything was just perfect a few weeks ago, until last weekend when i was going to use it, it just hang up or halted all the time. and now I cant use it at all.
Only thing ive done with the phone is that i tryed to install tomtom just for fun, but didnt work. but i doubt this should have anything to do with everything.
IF there isn't some crap saved in the internal memory which makes it go straight to hell. considering that it ask me if I want to owerwrite the already installed program, which means it has to be,...
Perfect timing when you really need the program for tomorrow..
Have you got it installed to the phone or the memory card? Sometimes it gets a bit funny if you install it to the memory card.
Also, if it's installed to the phone you haven't changed your memory card recently have you?
No problems with R66, but then again: I've the legit version !!!
aiight now reinstalled everything through NSU and now it started up with no problem at all.
too shame the map doesn't seem to be the one with most up to date.
got my map from version Route66_Mobile_7.0.989
which one is the latest you can buy? and are the maps any updated?
