Caller Groups for 9290
2 replies · 1,851 views · Started 19 January 2003
Is there a way I can have caller groups on the 9290 so I can assigin different ringtones for different people that call me. Thanks in advance.[/b]
10 Views and still no answer? Hmm, where did the AAS spirit go?
Here you go my friend:
Open Lid
Go to contacts
Open the contact you wish to personalize
Menu=>CARD=>Ringing Tone=> Select
(or easier Ctrl+R)
This will bring in front Personal ringing Tone Menu. Default is <no tone>
In case you wonder Groups Ctrl+M or the Menu=>CARD=>Belongs to Groups.. command-select.
Got It?
In case you need some ringtones, you can find a lot in this forum, but you will need to register in order to see the atachments.
Tell us what you think after it....
