What's new in version 1.30:
- it's MUCH faster (50% faster if optimized for speed)
- four compression levels:
- maximum (up to 10% better compression ratio)
- normal (up to 5% better compresion ratio, the same speed as before)
- fast (up to 20% faster)
- fastest (up to 40% faster, slightly lesser compression ratio)
- all compression levels are still ZIP format (files compressed with Space Doubler can be extracted using e.g. Winzip)
- Space Doubler application size is 15kB SMALLER
- faster and more discrete start of compressed applications
- ability to create shortcuts to compressed applications in standard Favourites application
- application/group settings added (e.g. frequently used applications may be optimized for speed with fastest compression level, others with maximum compression level)
- Space Doubler is now fully automatic, it detects new applications and asks about compress it (no need to run main program after instaling new application)
- ability to "sign" or not application icon
- Repack all applications option added
- smoother progress indicator
- other changes...
- and it is available as FREE upgrade to registered user's 😃 😃
sDoubler 1.30!!!!
Thanx but its already in the 7650 news section 😊
