Hi Im on 3 and have the Broadband plus bolt on with "3", my only problem is when i use my phone as a moden using the USB cable and nokia PC Suite, i cant sign into Windows Live on my PC, i click sign in and after a few seconds it just goes back to the sign on screen, ive called 3 and they where useless, they just told me to reinstall Messenger, which hanst worked, ive gone to the connection settings on messenger and it seems to think im not connected, does anyone know what i can do??:con? :frown:
Nokia N73 and "3" Broadband Plus - Windows Live Messenger
It works for me, with another phone... So, do you have the last PCSuite software version installed? When the connection is made, there is another software running onbacjground on phone, that may use the same modem?
Hi thanx for the reply, i may need to update the software as im just using the one that came on the CD, sis you say that there is another program running on the phone when your on the internet??
