Multimedia Key animation really slow!!
1 replies · 2,124 views · Started 30 September 2007
hey there,
is there any way to disable the multimedia key animation? it takes ages to load compared to just clicking menu and the number to which folder and file u want to go...
atleast before we had a goto option before...now i cant even find that...
plus is there any way to set shortcuts to FILES you quickly want to access?
thnx alot?
is there any application to set shortcut to "files" (maybe on the active standby), like an excel file u access frequently?
and is there anyway to change ur mutimedia keys "press and hold" program shortcut on N73?
i found this key a waste cuz using the menu key and pressing respective numbers to the folders or the applications u want to go to is so much more faster...ne tweaks to make it?
